Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 04-14-2006, 06:47 PM   #1
barney boy
barney boy Normal reputation
Unknown Warning Light Bus 5
I have a warning light on the dash that reads Bus 5 or it may be Bus S. How do I find out what this is??
barney boy is offline   Reply With Quote
Old 04-15-2006, 12:10 AM   #2
dave92cherokee
dave92cherokee's Avatar
dave92cherokee Normal reputation
Re: Unknown Warning Light Bus 5
what year and model jeep is it and where on the dash is the light located?
dave92cherokee is offline   Reply With Quote
Old 04-15-2006, 06:58 AM   #3
barney boy
It's a 2000 Jeep Cherokee Sport. It currently won't start. The engine turns over but doesn't start. The message is where the mileage usually is.
Old 04-15-2006, 11:38 AM   #4
kennzz05
kennzz05 Normal reputation
fastest thing would probably be to call a dealer
kennzz05 is offline   Reply With Quote
Old 04-15-2006, 12:09 PM   #5
barney boy
They just say to bring it in (the dealer).
Old 04-18-2006, 09:49 AM   #6
xj31
xj31 Normal reputation
The bus is shorted.The bus is the circuits that all the modules use to communicate
xj31 is offline   Reply With Quote
Old 04-18-2006, 10:26 AM   #7
barney boy
Thank You!!! Now, can you tell me where that is?
Old 04-18-2006, 06:05 PM   #8
xj31
its basically throughout the whole jeep.The bus connects the pcm,tcm, airbag module,door modules,abs,cluster overhead module,etc.the wires are purple and white and they are twisted together.they are inside most of the harnesses so I wouldnt just go and start trying to find the problem.A lot of times a module can be shorted internally and that will bring the bus down.Usually I will start by unplugging modules one by one and see if it comes back.Also wiggling harnesses can help you find it if its in the wiring.
Old 05-11-2006, 11:26 PM   #9
Stouttrout
Stouttrout Normal reputation
Barney Boy,
Did you ever get this fixed? I am having the same problem. It happened to me once before and I pulled out all of the fuses and it started right up. Did it again and the same thing. Pulled a loose fuse and it started right up. the Previous Owner did some crazy stereo wiring. I think he bent one of the fuse holder prongs. Now the Jeep is at fab shop and they can't start it to drive it around and test the work out. I am 120 miles away.
Anyone know if there a fuse I should tell him to look for?
Stouttrout is offline   Reply With Quote
Old 05-12-2006, 08:33 AM   #10
Stouttrout
Got it It was a fuse. We jumped a link over them and wham!!! Fired right up. It was the first 20 amp from the bottom on the row closest to the frnt of the Jeep. I am going to run a fuse link off of it so it will not happen again.
I would like to hear what your problem was if you got it fixed.
Dan
Bookmarks
Google
Web AF
