Wheel Bearing Nut/Can't get it offgolf4dj 07-14-2002, 11:52 PM Any suggestions out there getting a wheel bearing nut off. I am attempting to replace the CV boots and get get the nut off. I just bought the car and it has spent most of it's life in Minesotta and the undercarriage has quite a bit of rust. A friend and I attempted to get the nut off and broke 2 craftsman 1/2 in breaker bars in the process. I need help!!! eeyore 07-15-2002, 09:07 AM you've a few options here. The first is to get a breaking bar with extension arms. Get a good quality bar and it won't break. I don't know about craftsman (live in uk), but I've had a "king dick" brand running at 6ft long with two people hanging off the end without breaking. I'd imagine "snap-on" would be the same. The second is to try heating the nut up with a blow torch. This should expand the nut and break and locktight fluid that is on it. The third is to use a nut splitter and crack the nut, but obviously you'll need a replacement nut. Saying that, either of the options above and you should use a new nut anyway. golf4dj 07-15-2002, 05:36 PM Thanks for the input. I did not think of heating the nut before prying. "Craftsman" tools are pretty solid. Both times I was hanging off the end of the 1/2 inch breaker bar with a 3ft extension when it broke. I am looking into a 3/4 socket, they are just much harder to find and certainly more expensive. wisey 11-14-2005, 05:41 AM does any one know how to undo the rear wheel bearing nut on a j reg primera. cheers J..M 04-21-2006, 09:38 PM does any one know how to undo the rear wheel bearing nut on a j reg primera. cheers Yeah with a 30mm (or is it 28) socket & some muscle power Automotive Network, Inc., Copyright ©2012
