2001 coolant leakAJBK 04-14-2006, 01:48 AM Hi gang, There is coolant routinely leaking out of the overflow on the passenger side. Puddles are normally about baseball-sized in diameter. Hoses look good, the water pump area looks dry. Is it possible the overflow container is cracked? Or any other ideas? Thanks in advance! KimMG 04-15-2006, 03:16 AM Yes. Have the radiator cap pressure tested. GPFred 04-15-2006, 02:10 PM I had to replace my 98 Taurus overflow bottle a few years ago, it was split on the bottom of the bottle and like you I wasn't able to tell where the leak was coming from until I had it pressure tested. It only leaked when the engine was at normal running temp. Good Luck. Automotive Network, Inc., Copyright ©2012
