Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Oldsmobile > Nonspecific
Old 04-13-2006, 08:13 PM   #1
tealse
tealse Normal reputation
Please Help..trans Problem..
I hope that maybe someone out there can help me out.I have a 1995 olds acheiva 3.1 with 4 speed automatic trans.I have been having shift problems that I cannot figure out.It started when it would shift hard into 1-2 then hunt for 3-4 gears. The whole car would shutter as if it was stuck in o/d.So I dropped the pan and replaced the trans fluid and new filter and it did improve greatly.Now sometimes it will run and shift smooth as glass but then all of a sudden start acting up again.I replaced the fuel filter /pcv valve and checked all vac lines and connections and nothing seems out of place.The car will not throw any ses lights when it is acting up so I dont believe I can scan it for codes.I am at my wits end .I tried to disconnect the tcc selonoid and the car stalled like it is supposed to so that would eliminate that.What would you guys recommend that I could try or has anyone had this problem before??It is a 1995 olds acheiva s with 3.1 and 4 speed auto trans with 140k...Any help is greatly appreciated in advance.Help please this is my wifes daily driver...
tealse is offline   Reply With Quote
Old 06-21-2006, 11:54 AM   #2
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Re: Please Help..trans Problem..
How long since you last tuned it up? Many shifting problems can be attributed to poor engine performance. IF you don't know how long it's been, try a tune-up (plugs, wires, fuel filter, PCV valve) and see if it improves. If not, you may have a sticking shift solenoid or pressure control solenoid.
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Bookmarks
Google
Web AF
