2000 Sport multiple cylinder misfirevsecord 04-12-2006, 08:45 PM I found an article from a tech on the problem.... My check engine light is on. I haven't lost power but it is idling really rough..... Let me quote what this guy says "Check engine light likes to come on. Again, it's a Jeep thing. Mainly, while working at the dealership, 99 percent of the time this was either a single or multiple cylinder misfire. Easy enough...change the plugs, add some DIY heat shieilding, and disconnect the battery. Be on your merry way. " My question is: What is the DIY Heat Sheilding? Where do you put it???? sector95 04-15-2006, 09:37 PM DIY... as in "Do It Yourself" Heat shielding.... some folks place a heat shield under the intake manifold to help deflect the heat radiating off the exhaust manifold. This shielding could be many things: wrapping the exhaust manifold with special insulating manifold tape or installing a sheet metal shield to the underside of the intake manifold are two that come to mind. mike 00XJ Automotive Network, Inc., Copyright ©2012
