Serpentine beltsMirock 04-11-2006, 09:10 AM Anyone can tell me how to chenge a serpentine belts on a 740 IL 1999 , i can't find way to do it the tensiner set up is different than most cars:banghead: .How to loosen them up.Please quick responde necessery. Bear 04-13-2006, 12:07 PM Go to www.realoem.com and the BMW parts and check out the engine and belt drive (pictures). I believe you have the dog leg style (like my 1988 750) and there is a bolt through a bolt head at one end of the leg and a bolt that acts as a pivot at the plate with the slot for adjusting tension. Loosewn all bolts and then using the double bolt, you put a wrench on the fixed bolt and adjust and then while holding that bolt tighten the bolt that goes through the fix bolt head. After that, tighten all oter bolts. Automotive Network, Inc., Copyright ©2012
