My car was running perfect, no engine noises, great performance, except I had that pesky 'what in the heck is happening with the coolant?" problem. The mileage is just under 100,000 so I thought I would buy a new rad cap along with the tune-up items. Right at 100,003,it started running rough on the freeway, my cervice engine soon light starts blinking and stays blinking until I pulled over at the next exit, The temperature gage right in the middle. (a friend of mine thought it or my thermostat was broken because it always pointed on cold) At the station it was running rough, and big white clouds of smoke was coming out of the exaust. I checked the coolant it was low, real low, but the engine didn't seem to be hot, I checked the oil after turning the car off, and it had gained about a quart of fluid. It was not milky, just a lot thinner. I started it back up, still running rough, and drove around the corner to my house. Before I turn this story into a novel, I'll tell you where I'm at now. I have got the upper and lower intake manifold off, I was convinced it had to be one of the gaskets. (Please don't ask about the compression check) I found no sign of blown gaskets, It looks like it had been worked on before. I found the water bypass pipe was broken, and someone just stuck it back it the hole and permatexed it. Well that's about it. Since I didn't do a compression check, what do I do now? Oh, and should I get some Halogen fluid along with those gaskets?
