Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 04-09-2006, 08:27 PM   #1
ninjazx6
ninjazx6 Normal reputation
Angry will idle but stalls when you push gas
i recently bought a 94 blazer 4.3 vortec and it is hard to start. when i finally get it started it will idle but as soon as i press the gas it bogs out and stalls. i replaced the cap and router wires plugs fuel filter and pump. i cannot figure out what the problem is. if i press the gas slowly it will rev up to about 3\4 throttle before it bogs out but if i hit the gas to the floor it will automatically stall. when i put it in drive and hit the gas to move it will bog out instantly. if someone knows anything about this let me know please for i am out of ideas
ninjazx6 is offline   Reply With Quote
Old 04-09-2006, 09:24 PM   #2
Markgc
Markgc's Avatar
Markgc Normal reputation
Re: will idle but stalls when you push gas
Do you have any fault codes showing. I think that will be your next step.
Markgc is offline   Reply With Quote
Old 04-09-2006, 10:31 PM   #3
Teal95Jimmy
Teal95Jimmy's Avatar
Teal95Jimmy Normal reputation
Send a message via AIM to Teal95Jimmy
How's your air filter. Your truck doesnt need much air at idle, but as soon as there is load put on the engine, or in your case you reving it up, it requires much more air.
Teal95Jimmy is offline   Reply With Quote
Old 04-10-2006, 05:24 PM   #4
cleanshavenrsx
cleanshavenrsx Normal reputation
Send a message via AIM to cleanshavenrsx Send a message via MSN to cleanshavenrsx
sounds like it cant breath
cleanshavenrsx is offline   Reply With Quote
Old 04-11-2006, 02:17 PM   #5
Lovedb4ever3
Lovedb4ever3 Normal reputation
yes either air filter or a map sensor. the map sensor senses the load on the engine if it is reading incorectly then it would die when u hit the throttle
Lovedb4ever3 is offline   Reply With Quote
Bookmarks
Google
Web AF
