Turbo oil lines...in/out?
eurobeaner
04-07-2006, 05:06 PM
OK, i know how to run the lines, i know how to run everything... BUT! Which side of the turbo is the oil in... and which is the oil out? there are two holes(obviously) and you want the oil out line to go strait down so it has a good gravity flow strait to the pan. oh, the turbo is a t3/t4... ssautochrome if you really want to know.... I KNOW! i didnt buy it, im putting it on for a friend. Any help would be appreciated! thanks.
Schister66
04-07-2006, 08:17 PM
small side is oil in....and the big one is oil out. The big hose should be a .5+" braided steel hose while the feed is a smaller 1/4" line. Usually the outlet hole is a square port too....
i'll have some pics in a few min...
Schister66
04-07-2006, 08:39 PM
well my gf took my camera w/ her so i cant take pics of my turbo, but if you need them, just PM me w/ your email address and i'll get some pics to you
usually the drain side uses a flange like this and a big fitting like the blue one...
http://i33.photobucket.com/albums/d61/Schister66-2/610815DF.jpg
http://i33.photobucket.com/albums/d61/Schister66-2/D8FD23D6.jpg
eurobeaner
04-07-2006, 09:30 PM
okie dokie! got it now... thanks, thats all i needed to kno.
Schister66
04-08-2006, 03:21 AM
alright, if you have any other questions, post them up or PM me
superbluecivicsi
04-08-2006, 03:15 PM
http://www.honda-tech.com/zerothread?id=109160 -oil return line setup
http://www.honda-tech.com/zerothread?id=114490 -oil return line parts
http://www.honda-tech.com/zerothread?id=71999 -where to weld oil return
http://www.honda-tech.com/zerothread?id=119100 -oil return line
http://www.honda-tech.com/zerothread?id=119539 -oil pan welding
http://www.honda-tech.com/zerothread?id=119715 -oil pan welding
http://www.honda-tech.com/zerothread?id=118687 -oil grade to use
http://www.honda-tech.com/zerothread?id=118694 -ft for oil feed line
http://www.honda-tech.com/zerothread?id=118807 -oil feed line
http://www.honda-tech.com/zerothread?id=119681 -oil feed line
http://www.honda-tech.com/zerothread?id=93550 -part for oil feed line
http://www.honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
http://www.honda-tech.com/zerothread?id=126335 -oil t question
http://www.honda-tech.com/zerothread?id=125438 -another place to buy oil lines
http://www.honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
http://www.honda-tech.com/zerothread?id=134078 -feed diagram
http://www.honda-tech.com/zerothread?id=133948 -oil bpst fitting again
http://www.honda-tech.com/zerothread?id=144586 -oil feed line restrictor
http://www.honda-tech.com/zerothread?id=155510 -oil leaks
http://www.honda-tech.com/zerothread?id=158018 -oil feed 3' better
http://www.honda-tech.com/zerothread?id=156571 -oil pan bolts
http://www.honda-tech.com/zerothread?id=170223 -oil pressure readings
http://www.honda-tech.com/zerothread?id=168084 -oil feed fitting
http://www.honda-tech.com/zerothread?id=131450 -oil feed diagram
http://www.honda-tech.com/zerothread?id=195068 -oil pressu
http://www.honda-tech.com/zerothread?id=364948 -BSPT and NPT AN explanation. ***
thank TeStUdO from HT.
