Car Pedals 106 IndependenceJames50 04-07-2006, 04:47 PM Hey, I have a Peugeot Independence 1.1 106 (2001), The pedals are quite small on the car, I am wondering if any of these Pedal Kits will fit my car fine? http://www.extremeautoaccessories.co.uk/products.php?section=57 If they do fit are they hard to put on? Thanks, James. lewi103 06-15-2006, 03:47 PM you can buy bigger pedals, you just drill a hole and screw them on, but ECE regulations say you must have at least a 50mm gap between each pedal and the sides of the footwell. because the 106 has a small footwell the pedals themselves are quite close together you might not be able to use some of the kits. If you go to a shop that sells them, on the back of the box is usually a template so you can see if they fit your pedals leaving the required gap. Automotive Network, Inc., Copyright ©2012
