loud scraping noise
Google
Web AF
taurustrouble
04-05-2006, 11:05 PM
My left back tire has this loud scraping noise, mostly when i am at a slower mph, I looked at the tire and i can see metal scrapings on the inside of the tire, it is coming from the Rotors? or the flat disk behind the tire, i think my brake isn't rlelasing, or something else, but there is an obvious indentation all around the disk(rotor), snd i am jsut wonder what it might be? please help!!!!
shorod
04-05-2006, 11:23 PM
You want to get this fixed ASAP. Hopefully it isn't too late already. You may have a sticking caliper and/or slide pins, but hopefully you just have worn brake pads (linings) and it hasn't destroyed the rotor yet.
In other words, it sounds like your brake linings are worn down completely and at a minimum you need new brake pads on the rear and a new brake rotor.
-Rod
e_powers
04-06-2006, 08:17 AM
i very much whole heartlly concure.
the next place you drive your car should be the shop. unless you plan to fix it your self. it would be best if it were towed
Google
Web AF
