how much tranny fluid?
danielc22
04-05-2006, 02:48 PM
i took the pan off to change the filter so how much fluid am i going to need to fill it back up?
das2123
04-05-2006, 04:27 PM
i took the pan off to change the filter so how much fluid am i going to need to fill it back up?4 quarts of Mopar ATF+4 should do you fine!
danielc22
04-09-2006, 06:50 PM
ok everything is back together but when the car is warmed up there is no fluid on the dipstick at all, what is wrong?
das2123
04-10-2006, 09:57 AM
ok everything is back together but when the car is warmed up there is no fluid on the dipstick at all, what is wrong?You probably need more fluid then. 4 quarts should have been enough, but maybe you need 1 more quart. Add it slowly and keep checking the level, you don't want to overfill.
danielc22
04-10-2006, 01:41 PM
i put 5 quarts in and still nothing on the dipstick
das2123
04-10-2006, 02:26 PM
i put 5 quarts in and still nothing on the dipstickYou didn't drain the converter did you?
danielc22
04-10-2006, 11:04 PM
i dont know how to , all i did was drop the pan and pull the filter off.
das2123
04-11-2006, 08:41 AM
i dont know how to , all i did was drop the pan and pull the filter off.OK, then add and check carefully!
