Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Taurus/Taurus Wagon
Old 04-05-2006, 08:56 AM   #1
pumkin
pumkin Normal reputation
chaneada
to whom it may concern,
i have a 95 ford taurus its not getting any fire through the spark plugs.but i replace them and distribution,ignition module,wires,coil ignition.snd it still won't start upbut it turns over. can some one help me with these problem
pumkin is offline   Reply With Quote
Old 04-05-2006, 01:44 PM   #2
shorod
Taurus Guy
shorod's Avatar
shorod Normal reputation
'95 Taurus won't start (Was: chaneada)
Just out of curiosity, what does the original subject mean?
Which engine does your '95 have, the 12V, 24V or SHO?
Are you SURE that you don't have spark? Do you have plenty of fuel, or are the injectors not firing either?
You may have a bad crankshaft position sensor and/or camshaft position sensor.
What is your battery voltage? If the battery voltage drops too low during the cranking, the PCM will not function properly and may not be triggering the coil(s).
-Rod
shorod is offline   Reply With Quote
Old 04-05-2006, 02:12 PM   #3
pumkin
Re: '95 Taurus won't start (Was: chaneada)
spark plugs not getting any fire. the car is taurus gl model.fuel injector is firing
Old 04-05-2006, 11:39 PM   #4
shorod
Taurus Guy
shorod's Avatar
Re: chaneada
Since in your private message you mention your car has the 3.8L, then you probably have the Profile Ignition Pickup (PIP) in your distributor rather than a crankshaft and camshaft position sensor. If the PIP is bad, it will not send a signal to the PCM or the Thick Film Integrated (TFI) ignition module which triggers the coil. If the PIP is working but the TFI ignition module is not, again you would not get spark.
Since your fuel injectors are firing, I would suspect that the PIP is working properly. The TFI ignition module is the most likely suspect based on the information you've provided.
Good luck!
-Rod
Old 04-06-2006, 09:36 AM   #5
pumkin
Re: chaneada
i also change the pickup module i did that first.ignition module in it to see what happen with this.so hopeful this will fit the problem.
Old 04-06-2006, 01:21 PM   #6
shorod
Taurus Guy
shorod's Avatar
Re: chaneada
Yep, sorry, I didn't notice that you already listed the ignition module in your original post.
At this point, I'm not sure how much more I can help without actually seeing the car in person with an oscilloscope. You don't happen to have an oscilloscope, do you?
Have you checked for voltage to the primary of the coil and checked for spark out of the coil?
What state are you located in?
-Rod
Bookmarks
Google
Web AF
