Starting ProblemSCOOBY37151 04-05-2006, 02:32 AM I Have A 91 Acura Integra When I Turn The Key The Starter Motor Dosen't Turn. Replaced The Starter Motor And The Ignition Coil Same Problem. Checked The Starter Relay It Checked Out Ok. What Else Should I Check? CHECKED ALL FUSES(ECU,.ETC). whitGSR07 04-10-2006, 08:55 PM neutral/safety switch....connection from positive post to starter...starter ground. Don't know what 91 integra has but...camshaft pos. sensor or crank pos. sensor. clampjockey 04-20-2006, 10:18 AM check your body grounds. hope it helps. gl. clampjockey 04-20-2006, 10:19 AM oops, sorry, I see whitgsr07, already said to do that (starter ground). my bad. Automotive Network, Inc., Copyright ©2012
