odometer and cruise control stopped working
Google
Web AF
baldhead
04-04-2006, 04:53 PM
on my 96 gl my odometer and trip clock stopped working everything else in the cluster work though.but then a couple of days later the cruise stopped working (the indicator doenst even come on) ive checked the fuses none look blown and everything else works ie:horn radio ect.
shorod
04-04-2006, 11:40 PM
Does the speedometer work fine? Do you have the Flexible Fuel Vehicle (FFV)?
The Vehicle Speed Sensor (VSS) could cause both of these issues, but I would expect the speedometer to not work as well.
You might also have a grounding issue or bad flex assembly on the instrument cluster. There have been a couple of threads about bad flex assemblies recently.
-Rod
baldhead
04-05-2006, 03:42 PM
hey Rod,
no I dont have flex fuel and the speedo works fine. the problem w/ the odometer started after my last fill up when I reset the trip clock. I checked the ground on my batt. the other day when checking fuses it didnt have a good connection i think i got that fixed permanantly. thanks man ,Baldhead
shorod
04-05-2006, 11:26 PM
Sounds like the odometer is probably a mechanical issue. Just for the heck of it, try pressing the trip meter reset button completely one or two more times. I've seen before where if I didn't fully depress the reset, the odometer would zero or usually not quite zero out and fail to record distance. Simply pressing the reset again completely would solve that problem.
Good luck!
-Rod
baldhead
04-06-2006, 05:13 PM
thanks but that was my first reaction(to push reset a few times). oh well but any ideas about the cruise. the horn and rear defrost work. once again thanks
shorod
04-06-2006, 06:07 PM
If you feel like tracing the schematic, I can e-mail you the pages for 1998. If you want them, send me a private message with an e-mail address for you that can accept PDF attachments. Also, please include a sentence with your request so I don't have to try to remember who requested what.
Have you verified that the cable to the throttle body is not broken? Also, there should be a brake pedal switch for the cruise separate of the switch for the brake lights. You may want to make sure the switch works and wiring to it is good.
-Rod
shorod
04-06-2006, 11:39 PM
I re-read your original post and see that the indicator does not even come on for the cruise, so even if the cable linkage is broken, that wouldn't explain the indicator not even illuminating.
Do the buttons on the steering wheel feel normal? Ie: can you feel a positive detent when you press the "on" and "off" buttons? At the speed control module, check for battery voltage at pin 5 (light green wire). If you don't have battery voltage, now check for continuity to ground. Checking for battery voltage is just so you won't burn up your meter if you were to check for continuity when there is battery voltage present.
If you have definite ground potential at that terminal (switch input for speed control module) that is probably why your cruise control will not turn on. You proabably have a bad switch that is always shorted to ground.
-Rod
baldhead
04-12-2006, 01:12 PM
I had an electrician friend of mine help me with using the schematic to find the problem w/my cruise cont. after some testing he suggested we go around the block and try the cruise. problem found either the indicator light is dead or not connected for some reason or another. i would like to fix that if i can but not improtant thanks for all the help
Google
Web AF
