94 Lumina code 32
Google
Web AF
BP1
04-04-2006, 03:14 PM
My '94 gives a check engine light when you first decelerate on the freeway. It resets when you restart the car and again will come on the first time you decelerate on the freeway. It reads code 32. I installed a brand new EGR. No change. Any ideas would be appreciated. BP
maxwedge
04-04-2006, 04:01 PM
Make sure the egr passages are clean, try to manually operate it and see if it stalls or gets real rough at idle.
BP1
04-04-2006, 04:14 PM
I cleaned the passages with carb/choke cleaner when I replaced the EGR. I will try manually operating it after work as you suggest.
richtazz
04-04-2006, 05:22 PM
Your EGR valve is a 3 solenoid electronic valve, so it can't be operated by hand.
maxwedge
04-04-2006, 07:28 PM
Good point Rich, missed that one. You would have to ground the constantly powered solenoids to confirm the passages issue, even then it is hit or miss whether a small amount of restriction could set a code.
richtazz
04-05-2006, 05:18 PM
no prob Max, it's getting harder to remember what years use what. You've covered my back, I got yours this time.
BP1
04-05-2006, 05:24 PM
Someone told me a new aftermarket EGR could be the problem, but it did look identical to the original. Also does the intake manifold need to be removed to properly clean the passages? Could the EGR solenoid be bad? Where is it at? Thanks so far, BP
richtazz
04-05-2006, 05:30 PM
The tube that runs to the rear exhaust manifold and the adaptor that bolts the EGR to the intake are separate from the upper plenum and can be cleaned independently.
Google
Web AF
