2000 Malibu Transmissionrushka 04-04-2006, 09:55 AM 2 Months Ago My 2000 Malibu Started Having A Neutral Flare In 3rd And 4th Gears. My Mechanic Ran A Diagnostic On It- No Codes. He Suggested It Might Be A Problem With The Computer, But Recommended A Second Opinion. The Dealer Said I Needed A New Transmission With A $3000 Price Tag. After 2 More Opinions I Replaced The Transmission With A Used One. Problem Is I'm Having The Same Problem With This Different Transmission. What's The Likelyhood That It Really Is The Transmission? Any Ideas What The Problem Is? maxwedge 04-04-2006, 12:06 PM Has anyone done a full scan with a trans function scanner to look at solenoid operation and slippage errors and yes the used trans could have the same problem. richtazz 04-04-2006, 12:38 PM I agree with Max, you need to scan the for trans codes, as it could be a wiring, ECM or neutral safety switch issue. rushka 04-04-2006, 04:06 PM I doubt the dealer did a full scan- I'll see if I can convince them to do that this time dgallo_2000 04-11-2006, 09:44 AM What is your symptoms? I drive along at 50 to 55 mph and my RPM's are screaming at 5000. rushka 04-11-2006, 10:52 AM What is your symptoms? I drive along at 50 to 55 mph and my RPM's are screaming at 5000. When I drive up a long hill and keep the accelerator level the car has a shudder. My RPM's are only fluctuating about 100. tractorboy 04-13-2006, 03:08 PM at 55mph the RPM should be around 2k. If you accelerate from a dead stop can you feel the car shift through the gears ? dgallo_2000 04-13-2006, 03:15 PM I can feel my car shift from 1 to 2, and I think 2 to 3, but not to sure. When I get to 5o mph, and I lay off the gas, to keep the speed, then reapply the gas, to maintain speed, it feels like my motor is going to drop. I got a friend, who owns a shop, to look at my car this weekend. If you have an answer, let me know... :banghead: rushka 05-05-2006, 03:47 PM Has anyone done a full scan with a trans function scanner to look at solenoid operation and slippage errors and yes the used trans could have the same problem. Ok guys- I took it to another dealer who did full scans- nothing. They cleaned the mass air flow sensor and that worked- for a week. Now its back. Any more ideas? :crying: maxwedge 05-05-2006, 08:34 PM Ok did they check for tcc operation and tcc slippage on a trans function scanner? maxwedge 05-05-2006, 08:51 PM To add, it is not a matter of codes but to eliminate or confirm a trans problem, the tech can command and confirm tcc operation and slippage errors for both o/d and tcc. Automotive Network, Inc., Copyright ©2012
