quick ? bout cd playerJiGGaG20 07-11-2002, 11:30 AM i am looking of changing the head unit for my ride...was wondering do i have to bypass the amp to get the new unit or no? lemme know please thanks THE CITY ONLY holla at the boi! Swonder67 07-11-2002, 10:48 PM yes At first it will be ok, but after a while, the stock amps will crap out. golf4dj 07-12-2002, 04:14 PM I have had good success with changing the headunit only and putting in a db reducer as an interface to lower the output signal to the stock amps. This is the easiest and most cost effective way to put a new head unit. It also sounds pretty good and too most ears you could not tell the difference from stock as long as the wire leads have been properly insulated (taped really good). Just my opinion. I just did this on my 93.5 G20, I have done it in the past on a nissan maxima and 300 ZX with similar results. You can get a db reducer from Walmart of all places for less than $20. Hope this helps, DJ boingo82 07-12-2002, 04:30 PM On my '94, I just ran the preamp outs into the amps..works great. Buy a headunit with preamp outs and you'll be fine. lloyd_nickens 07-12-2002, 09:39 PM You also wont have to turn the volume up as much, if you do go the route of using your speaker outputs to the factory amp. Automotive Network, Inc., Copyright ©2012
