Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > LS400/LS430/Celsior
Old 04-03-2006, 05:27 PM   #1
phantastic1
phantastic1 Normal reputation
'99 LS400 engine compatable w/ '00 GS400???
got a 99 ls400 w/ a blown block due to some recent flooding in the area. the local salvage yard has a 00 gs400 engine. my question is....would the gs400 engine bolt right up and work in the ls400? both are 1uz-fe...however...both long blocks has 2 different part numbers. if it does bolt right up....then what are the differences in the 2?
phantastic1 is offline   Reply With Quote
Old 09-13-2007, 08:25 PM   #2
Stealth91
Stealth91 Normal reputation
Re: '99 LS400 engine compatable w/ '00 GS400???
Well, first off, if the GS engine has a flywheel on it, make sure it bolts to the torque converter. if it doesn't have a flywheel, make sure it bolts to the flywheel of the LS. Even though they are the same engine, they have minor differences. The LS2 in the GTO and the Corvette produce about a difference of 50Hp dispite being the same 6.0L engine. Also, i would think you would need to get your ECU tuned to operate on the different engine because i am almost certain they modify the code from the ECU every new year
Stealth91 is offline   Reply With Quote
Bookmarks
Google
Web AF
