out of money whats wrong with tranny?91hatchgsr 04-03-2006, 04:36 PM finally have completed my gsr swap in 91 hatch now vehicle will not rev. past 3500 rpm thats not my problem when trying to engage clutch it grinds really bad shift into gear and nothing???????? clucth doesnt grind when releasing axles not spinning tranny fluid is new axles were seated properly and now i guess im going to have to drop the tranny what the hell do i do some one please help scott Sulsa 04-03-2006, 05:10 PM It won't rev past 3500, probably because your ECU is in hobble home mode. a sensor or the wiring for it is fubarred probably. As far as the tranny, my guess is it's focked. Hard to diagnose something like that, having never seen the car, tho. WReX 04-03-2006, 05:40 PM sounds like a bad throw-out bearing Sulsa 04-03-2006, 06:46 PM sounds like a bad throw-out bearing That shouldn't cause the axles to not move when he's in gear. I believe a bad throw-out bearing grinds whenever you disengage the clutch. WReX 04-03-2006, 08:41 PM i didnt know the car went into gear, i guess i read the original post wrong as for the throw-out bearing, it makes a noise when engaging also 91hatchgsr 04-03-2006, 10:49 PM alrite guys heres what i got tranny is out of car i put the pass side axle in the pass side of the tranny and put the half shaft in the drivers side (now remember tranny is out of car sitting on ground) when engaging the tranny into any gear i can spin the half shaft and the pass side axle will spin oposite way (as expected) but heres the catch i can have someone spin the input shaft and if i grab ahold of the pass side axle i can grab it and prevent it from spinning is that normal It really feels as if the axle isnt seating properly they are b series axles for sure! this is a ys1 tranny out of 1.7gsr i believe there is no lsd i have over 10 grand invested into the build of this motor and car and now after install i just keep running into problem after problem :banghead: i did how ever find that i may have launch control on my computer after it was programmed and chipped so as for the car reving out at 3500 i may have that problem solved, I HOPE! so i guess i wont know if this is true or not untill my first test run no codes, no check engine light so im very puzzled thanks for all ur info guys but does any one know for sure what this problem could be from clutch cable too long???? is it possible??? i made custome plate to hold and secure clutch cable so as for proper allignment with clucth cable thats out of the question how can u tell if the throw out bearing is shot i know my wiring is done correctly, (THANK YOU TO RYAN AT RYWIRE) PLEASE HELP!!!!!!!!!! Scott GSR HATCH (INCOMPLETE):banghead: 91hatchgsr 04-03-2006, 10:54 PM dude a throw out bearing makes what kind of noise im talking like serious grind almost as if ur smashed gears at an idle with no clutch i also heard when tranny was still in car and very high pitched wining noise almost like a super charged wine?? any ideas barkercustoms 04-04-2006, 01:06 AM simple fix go to the junk yard and get another tranny for like 100bucks and thro it in there if you have 10g in it another 100 bucks aint nothing 91hatchgsr 04-04-2006, 01:34 PM thats the thing OUT OF MONEY!!! any one know whats wrong with my car? Automotive Network, Inc., Copyright ©2012
