Re: 2001 Taurus Worn Strut Bearing???
I'm not sure if the 2001 uses the plastic anti-sway bar end links, but if so, you may want to inspect them to see if they are the noise.
As a side note, I was searching for a similar noise on a co-worker's Mazda Protege. He had taken it to a shop for the noise and they told him the noise was caused by bad front struts and gave him a $1200 estimate to do all four struts. He decided to tackle the job himself (with my tools, garage, and help) and bought the struts. When he brought the car over, I was convinced that the noise was not his struts. The struts were not leaking, the car didn't bounce excessively, and when he sat in the car and I tugged away at the sway bar end links, the noise in the cabin seemed identical.
The sway bar end links would need to be ordered, and it was his wife's car, so he decided he wanted to replace the struts anyway. So we did. Even when we had the old struts out and the springs removed, the struts did not compress overly easily and they started to climb back after being fully compressed. Anyway, we got the new struts installed and the noise was gone! Struts were the only part we replaced, and I would have put money on it that they were not bad.
We did not find any loose bolts in the process, etc. I did inspect the strut plates and opened them, they looked fine and did not need new grease.
-Rod
