turbo problemhany 03-31-2006, 05:36 PM i have a problem in my turbo . i have d15b vtec jdm and i use fmu. and it run very good during the boost but the problem is after the boost when i press at the fuel i found the engine need to stop . then i stop it and start again it go good. so what is that ? and note i not installed the o2 sensor . superbluecivicsi 03-31-2006, 07:39 PM what chassis? what ecu? one wire o2? not running o2 sensor...................so what cel(s) are you throwing? hany 04-02-2006, 02:01 PM [ ]what chassis? 1992 civic 4 door what ecu? p08 but is auto and i use manual tranny so the cel always light one wire o2? yes one wire o2 but iam not installed it and i use fmu with missing link so what is that ? CivicSpoon 04-02-2006, 02:25 PM First install an O2 sensor, you need it. You're not going to be able to even know how your air/fuel ratio is, since you need to hook up the A/F gauge to the O2 sensor. Things like O2 sensors and A/F gauges aren't things you can just go with out, you NEED them. And check your codes again, because you have to be throwing more than just the ones for the auto/manual tranny thing. At the very least you're throwing one for your O2 sensor as well. hany 04-03-2006, 12:46 PM ok i will do and tell you the result. thank you Automotive Network, Inc., Copyright ©2012
