dsm injectorsblitzcivic 03-31-2006, 02:42 AM hi i have a question in reguards to the 450cc dsm injectors. i was wondering do i have to use resistors if im having the ecu tuned. Schister66 03-31-2006, 08:23 AM If your car doesn't have a stock resistor pack, you have to have the resistor or the injectors won't work. They work on a 12 ohm resistance and your stock injectors might be at a 2ohm depending on the year of your car. I'm not really familiar with Hondas, but i think OBD1 is all P&H injectors....... If its boosted now, what are you using for tuning and what size injectors do you have?? superbluecivicsi 03-31-2006, 12:02 PM you can run it without the resistor box, but, you will regret it when the injector drivers in the ecu fries. Schister66 03-31-2006, 01:50 PM so basically if you don't want to f**k things up, you need a resistor...... Automotive Network, Inc., Copyright ©2012
