Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Taurus/Taurus Wagon
Old 03-30-2006, 11:55 PM   #1
TGG
TGG Normal reputation
Red face License Plate Lamp Bulbs
Please help? My license plate lighting is not working. First, I tried replacing the bulbs. When this did not work, I checked the socket for power. I found that I had no power coming to the socket. I have checked the fuses and do not appear to have a problem with them. I have searched the Haynes manual for a wiring diagram to track the source of my problem. There is a very small diagram that is hard to read and identify. Does anyone have a better diagram I can use? Your help would be greatly appreciated.
TGG is offline   Reply With Quote
Old 03-31-2006, 02:56 AM   #2
KimMG
AF - Advisor
KimMG Normal reputation
Re: License Plate Lamp Bulbs
You didn't specify year or if it is a wagon or sedan.
If possible make an enlarged copy of your wiring diagram.
Try autozone.com
They have free repair guides available.
KimMG is offline   Reply With Quote
Old 03-31-2006, 02:12 PM   #3
shorod
Taurus Guy
shorod's Avatar
shorod Normal reputation
Does your car have aftermarket trailer wiring? If so, the installer may have used the common (but inappropriate) ScotchLoc connectors.
These are fine for interior wire taps in dry locations, but when used outside the car or in wet locations, they do not prevent moisture from entering the wiring and corrosion from occuring. I've seen this type of wire tap cause numerous lighting problems which usually require the damaged wires to be replaced in 1 foot long sections.
If you find this to be the case, I would suggest replacing any of this type of wire tap with soldered splices, and all splices being insulated with adhesive-lined shrink sleeving.
-Rod
shorod is offline   Reply With Quote
Bookmarks
Google
Web AF
