1992 Toyota 4x4 V6 wont' start, need help.hank76 03-30-2006, 10:35 PM I have a 92 4x4 extened cab pickup with a 3.0 V6. I let the truck situp for about year. The battery was gone so I replaced it. The engine will turn and turn, but it won't fire. I tried spraying carb cleaner in the intake. After doing this the truck will almost fire for a second, but then just continues to turn. Does anyone have any suggestions. Thanks fourwd1 03-31-2006, 09:20 PM Do you have fuel pressure at the fuel rail ? Do you have spark ? hank76 04-02-2006, 08:14 AM I think I have a spark since the engine did attempt to start after I sprayed carb cleaner in the intake. I am in the process of replacing all of my plugs and wires just in case. I'm also replacing the fuel filter. How can I check to see if I'm getting any fuel pressure? I plan to syphon any gas in the tank out and replacing it with fresh fuel. Also, how can I check to see if I'm getting a spark? Thanks SidneyCanada 04-12-2006, 07:22 AM Always pull the ECU (EFI computer) codes & if no codes are stored then compare voltages & resistances at each ECU pin/wire then compare with FSM (factory service manual),see below for complete details.All of the links have been checked recently for validity,if not happy with my detailed info then I suggest you pay mechanic $60+/hr that's if they are honest and know what the are doing. About half of the ECU codes stored on the first & second generation EFI Toyotas don't show a constant blinking check engine light therefore you must pull the ECU codes to see if a fault is registered. To pull the ECU codes: All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner,the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it: http://autorepair.about.com/library/ts/obd-i/bl-dtcs-36.htm http://autorepair.about.com/library/ts/obd-i/bl-dtcs-53.htm http://autorepair.about.com/library/ts/obd-i/bl-dtcs-71.htm http://autorepair.about.com/library/ts/obd-i/bl-dtcs-90.htm http://www.off-road.com/toyota/tech/codes/index.html http://lcengineering.com/TechNotes/TechNote12.htm http://lcengineering.com/TechNotes/TechNote13.htm http://www.geocities.com/MotorCity/Pit/9975/dataBySubject/Engine.html http://www.mad-mechanic.com/toyota/toyotaobd.shtml#obtaincode http://www.freewebs.com/th3duke/22RE-ECU.mht http://www.troublecodes.net/Toyota http://www.autoshop101.com/forms/h27.pdf http://www.showmesome.info/hilux/info/manuals/1KZ-TE/Page0096.htm http://www.efisakh.narod.ru/at_toyota.htm (auto tranny codes) http://www.usatransdoctor.com/foreigntoyota.htm Pulling the ECU codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements both with the engine running and not and compare with the factory service manual,I also close the ignition switch after a cold engine and also after a warm engine and compare them with the factory service manual.This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's,vcr's,home/car audio. Sidney® ™ Repairs tv's,vcr's,home/car audio out of my home E-mail:sidneybek@yahoo.com Dartmouth,Nova Scotia Canada 1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 248 000 KM Automotive Network, Inc., Copyright ©2012
