Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 03-30-2006, 10:31 PM   #1
Repo_agent
Repo_agent Normal reputation
electric cooling fan wont come on 4.0L
Electric cooling fan on my 2001 Cherokee wont come on when air condition is turned on and I dont think it comes on by the temp control switch.
Checked fuses,relay and fan motor all are good.
Also I am getting a AUXILARY FAN CKT PROBLEM (open or short) code with the check engine light.
Any ideas?
Repo_agent is offline   Reply With Quote
Old 03-31-2006, 08:58 AM   #2
dave92cherokee
dave92cherokee's Avatar
dave92cherokee Normal reputation
Re: electric cooling fan wont come on 4.0L
Try connecting the fan directly to the battery to make sure that it still works after you reconnected it to the wire harness the way it is supposed to be. If it kicks on then that tells you that the fan is good, in which case drive the jeep for a little while to let the engine get to normal running temp and then park it with the engine running and pop the hood and turn the heater on in the windshield defrost position at max power and see if the fan kicks on. If it does then it's operating properly, if it doesn't kick on after a few minutes then unplug it from the harness and connect a volt meter to the harness for a few minutes and see if it's sending the voltage to the fan that's needed as it might be a problem in the wiring somewhere.
dave92cherokee is offline   Reply With Quote
Old 03-31-2006, 05:49 PM   #3
Repo_agent
Already did all the basics. That is why I said the motor is good. Im looking for a more in depth diagnosis like why the pcm isnt turning the fan on.
Old 04-08-2006, 09:25 AM   #4
nick0750
nick0750's Avatar
nick0750 Normal reputation
cooling fan relay 4608094 mounted in power distibution center
nick0750 is offline   Reply With Quote
Old 04-08-2006, 11:35 AM   #5
Repo_agent
In the original post I mentioned that the relay was good.
Old 04-09-2006, 12:10 AM   #6
Raimundo
Raimundo Normal reputation
Any ideas?
Clean all connectors. If still does not work, check the presure on the a/c.Do you realy feel cold air when you turn it on?
Raimundo is offline   Reply With Quote
Old 04-09-2006, 07:02 PM   #7
Dale Aeppli
Dale Aeppli Normal reputation
check switch on thermostat housing its in fan circuit Dale
Dale Aeppli is offline   Reply With Quote
Old 04-11-2006, 12:02 AM   #8
hardparts
hardparts Normal reputation
relay, oem 4848879AA
coolant temp or pcm
http://www.hard-parts.org/forum
New automotive tech site.
Just opened, come join us.
hardparts is offline   Reply With Quote
Bookmarks
Google
Web AF
