Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Taurus/Taurus Wagon
Old 03-28-2006, 09:23 AM   #1
harveysmith
harveysmith Normal reputation
Question 1992 Fuse Load/Hot side
Hello,
I want to install an "access-a-fuse" in my 1992 ford taurus fuse box to hook my scanner up to. Does anyone know if the left or right side of the fuse box is the hot/load side? Thanks in advance!
harveysmith is offline   Reply With Quote
Old 03-29-2006, 01:55 AM   #2
shorod
Taurus Guy
shorod's Avatar
shorod Normal reputation
Re: 1992 Fuse Load/Hot side
Do you have a multimeter or test light? If so, clip one end of either tool to a good clean metal ground, remove the fuse from block that you'd like to use, then probe both terminals in the fuse panel and which ever one cause the light to light or the DMM on Vdc to give a reading of battery voltage is the hot terminal.
-Rod
shorod is offline   Reply With Quote
Bookmarks
Google
Web AF
