99 Cherokee Sport - A/C question
gregshawjr
03-28-2006, 07:27 AM
On my wifes jeep, when we turn on the A/C, it sounds like the vent door isnt opening properly, and the front window defroster does not work and no cold air blows out, and actually you can feel a tiny bit of air coming thru the defdrost vent, but very little.
is there any easy way to access this A/C door and fix it?
gregshawjr
03-30-2006, 12:42 PM
anyone?
gregshawjr
04-18-2006, 01:24 PM
I just took the jeep to my buddy, he did a pressure test on the vaccuum - and said there was no loss in pressure or any leaks. He thern refilled the system with R134a and the jeep has been blowing cold for 4 days now. IF it were to leak out, how log would it take?
dave92cherokee
04-19-2006, 07:42 AM
It depends on the size of the leak and where the leak occurs in the system. If it's a pinhole leak it may take as long as a month to leak out or as short as a week depending on how heavily the a/c is used. If it's a pretty good leak then it will be out in about a week. As for the a/c door that you're talking about on my 92 the only way I have found to access the door's and such on the inside is to completely remove the dash from the jeep then you have access to the entire a/c housing and the heater core if needed.
lowbud
04-22-2006, 11:02 AM
If you pop off the frame around the radio and fan controls it will give you some limited access to that area. I had a friend who's wire became disconnected and I reconnected for him.
I have a '97 Cherokee that had poor A/C. I would recharge it but it only lasted about two weeks. Finally had to take it into the shop for repair. Appearantly Jeeps are known for the leak behind the dash.
