Squeaks?GTTIM 07-09-2002, 10:25 AM Maybe related to other post - but my p10 gt always squeaks from the back - is not very noisy but can be heard over just about any bump at low speeds. Any ideas as to likely culprit? boingo82 07-11-2002, 03:11 AM This thread might help. (http://www.automotiveforums.com/vbulletin/showthread.php?threadid=39558&highlight=creak) nismo_gt 07-13-2002, 04:24 AM The P10 also has a brake balancer underneath, these are inside 2 springs about 3/4 way down the car. These sometimes get dry & can give the symptoms your complaining of. Just lube them with some grease & see if it improves. dock 07-25-2002, 12:26 PM Hey boingo82, I'm experiencing the same noise in my g20 that you described from the other thread. Did you ever figure out what the noise was, or fix it? If you did, could you tell me how much it was to fix and what it was? Thanks a ton! boingo82 07-25-2002, 03:02 PM Honestly I don't know if it's fixed, it only happened in weather under 70 degrees F and it hasn't been that cold in months. dock 07-25-2002, 04:21 PM Thanks, I guess I'll try some of the things mentioned in the other thread. My creaking first started to be only when it was cold out, but all of a sudden this summer it has started to happen all the time. Hopefully it's one of those things as it is very annoying! Automotive Network, Inc., Copyright ©2012
