I have a 93 Ford Taurus with the 3.0 automatic trans and it was driving along one day and just quit. I have spark jumping 2.5-3 inches at the coil and popping really well from the disty wire to the disty when I take the wire off and check it. Also can see it jump the plug gap. The fuel pump is coming on but here is the problem:
The fuel pump stays on with the key in the on position and the cooling fan stays on as soon as the key is turned to the on position. Every once in a blue moon you can walk out and start her up for sometimes 3 seconds and sometime 3 minutes. Then poof, she will shut off and before the crank stops turning the fan has noticeably cam on and running full speed.
Note, when it does start you can tell it will start as you turn the key on and the fuel pump comes on and goes off and then the fan is not on and wala! she starts right up only to shut off moments later and not to start again...
...this is the weirdest thing I've ever seen. Anyone got any ideas? Thanks for any help or ideas you can give me.
Frustrated in Augusta, GA!
PS I had taken the distributor out to check timing (stupid) then reset it and spark timed it. Today it started and was running rough and I reached down to move the distributor to get it to run better and blam the fan kicked in on high and the motor shut off and wouldn't start back up..???
Please send responses to
GANDL2123@comcast.net as well.
