Re: Frustrated Technician - 2+3 Misfire 2001 4wd
!!!UPDATE!!!
I figured it out. After 3 days, $50 Coil Pack, $8 Spark Plugs, $35 Plug Wires, and a $85 Cam Positioning Sensor! None of that worked, but when I checked the harness that goes to the harness plugged into the Coil packs, I was checking the harness with my ohm meter. After figuring out nothing, lol, I put it together halfway (half the bolts on the intake and snug fitting the PCV hose and such. I started it just to see and it WAS ALIVE on all four. So When I unplugged it at the connector underneath the intake manifold and plugged it back in, it must of been oxidation or something. No, no cracks in the exaust manifold, i had to take the heat sheild off to better reach the Crank Positioning Sensor. Besides a crack in the exaust manifold would only lower the backpressure in the manifold, as long as the valves are working, that shouldn't affect the compression in the cylinders so i don't understand why you said that could cause misfire. Well, anything's possible. I unbolted the exaust after the second CAT to see what it would be like. just left it loose on the bolts. Sounds alright, but it felt like it had a little more punch. I bolted it back together. Was only to test and poke around with the exaust. I think i'm going to take out the muffler and get a boom tube or glass pack. Any suggestions. I want a little more growl, but not a loud rattling bumble bee like you find in the Acura Integras.
