drive shaft assemblyjyun_91_LS 03-23-2006, 07:03 PM need a quick reference manual for passenger drive shaft install an removal, an also my 3rd gear is grinding a little bit.... could it be a synchro??... WReX 03-23-2006, 08:43 PM take off pass. wheel, lower control arm castle nut, lower suspension fork bolt and nut, wheel hub nut (32mm or 36mm) i forget, move all the suspension stuff out of the way and pull, should pop right out as for the grind, its a bad blocker ring on the synhro. assembly Automotive Network, Inc., Copyright ©2012
