Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 03-23-2006, 06:36 PM   #1
Newbie600rr
Newbie600rr Normal reputation
4l60e shift solenoid
I have a problem with my tranny. I have a 95 that has no 1st or O/D and all indications seems to be the shift solenoid. I have tried searching on how to test it but nothing seem to paint a clear picture on how to test it. Could somebody possible help me. I have codes 758,753 which are open circuits for shift solenoid A&B, and also code 1864 transfer case contact plate power open circuit/short to ground. Another possible cause is a bad ignition switch which seems to cause weird codes but would to cause you to loose 1st and O/D? Thank you for any information that you could give me.
Thanks Again
Chris
Newbie600rr is offline   Reply With Quote
Old 03-23-2006, 08:07 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: 4l60e shift solenoid
I show thes codes for a 96.
Does it have a pcm or vcm. VCM is the computer under the water tank on fender.
The code all together at one time points to power feed to transmission start with the fuse and wiring and 12 volt power to transmission.
I come up with the code 1864 is a transmission tcc circuit code.
This info and all info on it and all wiring and code test can be found in the All Data DIY online repair info sub. 24.95$ us a year but will save you a lot more than that on one repair.
Link below. MT
http://www.alldata.com/products/diy/index.html
MT
MT-2500 is offline   Reply With Quote
Old 03-23-2006, 08:45 PM   #3
Jeremy Fitch
Jeremy Fitch Normal reputation
Send a message via Yahoo to Jeremy Fitch
1996 Blazer LT 4 Door, 4x4, 4.3L Vin W.
Jeremy Fitch is offline   Reply With Quote
Bookmarks
Google
Web AF
