Urgent!! Short Throw Shifter Installkylekyle 03-23-2006, 04:36 PM Hey i need some tips on how to install a new ractive short throw shifter. ya ya i know i should of bought a real name, but i was told that they were all the same so to go with the cheap one! but any way, whats the easiest way to install and what precautions should i take? thanks for any replies Sulsa 03-24-2006, 02:29 PM The easiset way is to get a Helm's manual for your car, and it will walk you through it. On the other hand, it's pretty easy to do anyway, and I've heard good things about ractive. Brand names in import equipment are like brand names in clothing. The stuff is always more expensive than off brands, but you can't always tell the difference in performance, if there is any. Your mileage may vary. I assume you have an Integra. Here is how I remember it on my 94 Integra LS. You need to unscrew the shift knob, jack one side of the car up, use jack stands, trace where your shift linkage meets your shifter, unscrew the nuts and bolts connecting them, and the old one should pull right out. Insert the new one, reconnect the nuts and bolts, screw your shift knob onto new shifter, drop your car back on the ground, and give er a test drive. kylekyle 03-24-2006, 03:37 PM hey man thanks for the help, im gonna try er out this weekend, i didnt think id be jacking the car up tho... will the linkage me showing underneath the car or do i gott atake somethign off to find it?? Sulsa 03-25-2006, 12:52 AM Yeah, the linkage is 2 rods that run from the transmission to your shifter. You can see it plain as day under the middle of your car. You'll be working directly under where you see the stickshift in the cab. Schister66 03-25-2006, 12:52 PM its an easy install if you have a lift or someway to get underneath your car easily. I used a lift when i pulled my tranny on my GSR....you have to pull the shift linkage and when you're using a lift its all right there for you. Its probably an hour at most w/ a lift, but if you're stuck using floor jacks, it will take a little longer. One thing, i dont know if you need to or not, but if you have to pull the shift linkage off entirely, there is a pin where the linkage attaches to the tranny....you have to center punch it out carefully and partially press it back in.........saves time for sure!! TreStringz 03-26-2006, 10:51 AM Can u really tell the diffference with the short shifter? kylekyle 03-27-2006, 01:29 AM so....not so easy, lol we put it in today and the bottem of the shifter tht connects to the linkage is too skinny and there is extra space between the sifter and the linkage! and now because the part of the shifter tht comes out the bottem of the car is longer thn stock, the linkage scrapes on the heat sheild for the exhaust, so were shavin the sheild down tomorrow and tryint to put some bushings to get rid of empty space. but all tht bad stuff aside, really short throw, needs gettin used to tho, hard to find gears cause there so close!! lol thanks for all the help tho, it really did help! kylekyle 03-27-2006, 01:33 AM Can u really tell the diffference with the short shifter? no man people spend 50 bucks and 2 hours on replacing it cause its a cool thing to say, lol of course it does, its so sweet! Sulsa 03-27-2006, 02:30 AM Wow, that sucks about it not fitting right. I'd ask the person you bought it from, if they forgot to give you a bushing or something. Can you maybe take the heatshield off, and pound a trench just deep enough into it, so your shifter doesn't scrape it? Shaving a chunk out of it, might allow whatever it's protecting, to be damaged. Just a thought. Good luck either way, and glad I could help. Schister66 03-27-2006, 02:30 PM idk...my GSR has a nice shifter the way it is...new bushings and a Skunk 2 shift knob will make it all better.......try that. It worked for me! K2sInteg98 03-27-2006, 02:42 PM cheap brand shifters does matter. One day if yu try to shift hard, the cheap brand will break on you. Ive heard lots of horror stories about some ebay short shifters breaking on people when they were shifting hard. kylekyle 03-27-2006, 06:41 PM cheap brand shifters does matter. One day if yu try to shift hard, the cheap brand will break on you. Ive heard lots of horror stories about some ebay short shifters breaking on people when they were shifting hard. ya mines not an ebay one tho ebay is like 2 bucks mine was 50 oh well tho i like this one TreStringz 03-28-2006, 02:56 PM Did you have to remove that pin where the linkage connects to the gear box? kylekyle 03-30-2006, 05:59 PM Did you have to remove that pin where the linkage connects to the gear box? no i did not have to, we just took the bolt out where the shifter neets the linkage thn pout the new one in, still havnt pu tin somethign to fill teh space tho, oh well badboyzkustumz 04-06-2006, 06:19 PM hey kyle, spell check. anyway, there should be rubber bushings on either side of the short shifter where it connects...that way it isnt metal on metal and wont wear as fast. kylekyle 04-07-2006, 12:53 PM hey kyle, spell check. anyway, there should be rubber bushings on either side of the short shifter where it connects...that way it isnt metal on metal and wont wear as fast. alright i will try that, just get those bushings from like canadian tire or what? hardware store or what? thanks! nitebeest 04-09-2006, 04:19 AM I just installed a short throw shifter on my civic the other day. I got a B&M short throw. It came with all the bushings. The one you got should have come with bushings for the piece inside the shifter at the bottom and some for the sides when you rebolt it to the shift linkage. Also as for the shifter height do you have the pivot point all the way in the rubber shift seat (i forget the technical name for it)? If you don't have it in where it should be or if it's not even in there all the way that could be why it's scraping the heat shield. Automotive Network, Inc., Copyright ©2012
