96 altima gxeramos 03-23-2006, 02:45 PM i have a 96 nissan altima gxe that will start but after a few minutes will turn off & the has not even been moved & then will have problems to start again. sometimes will start & will acelerate to 4 or 5 rpm & feels like gas is not going thru or something?. also have a question on the ecu what is the normal & correct position of the flattened srew? needs to be all the way to left(counter-clockwise) or to right (clockwise) please help w/advise, by the way i recently changed the fuel pump & car still does the same, put a distributor from autozone 2 mnths ago. can it be defective? jserrano 03-23-2006, 02:53 PM Might be a clogged catalytic converter. The ECU screw can go either way but most people leave it counter-clockswise. JustSayGo 03-23-2006, 03:52 PM Very Likely the distributor is defective. The AutoZone distributors are reconditioned from distributors that they have no idea if there was an intermittent heat related problem. I replaced AutoZone Lifetime warranty distributors twice on the same Honda. On each occasion a few months apart the engine started immediately after replacement. After purchasing a new distributor at Ebay there was never a problem. The same signal from the distributor that initiates the spark at the sparkplug is also used by the ECU to actuate the fuel injectors. ramos 03-28-2006, 09:23 AM thanks for the advice, i wil try to get another distribuitor either from ebay or frm nissan. also how can i find out if catalitic converter is clogged? thank you again for any advise. jserrano 03-28-2006, 11:04 AM With a vacuum gauge T connector off the fuel pressure regulator. http://www.users.bigpond.com/ergoff/vac16.gif EXHAUST SYSTEM BLOCKAGE: high reading when engine first started, falling back to 1 or zero and gradually increasing to 15 or 17. Automotive Network, Inc., Copyright ©2012
