96 Altima air bag light flashing
bracketshark
03-21-2006, 08:47 PM
My 96 Altima air bag light has started to flash continuously. no check engine light on, any ideas? Thanks
FixUrNissan
03-23-2006, 06:47 PM
yeah this was known to happen alot. You can actually go into self diag using the door switch for the airbag system. Simple by pressing the door switch 7 time with in 10 seconds.. The problem your having is your in self diag. Simply get into your car and after turnig the key to the on postion click you door switch 7 times with in 10 seconds , then watch your air bag light .. it may go into a longer blink. Then you ll need to do this step one more time .. key off and again.. then after the 2nd time start the car ... the light should do it's normal systme check then go out.. you can give me a shout if you have any more questions
x1gary
03-24-2006, 09:28 AM
It stays on for 2 Seconds, then flashes 7 times then goes out. It then repeats the cycle.
bracketshark
03-24-2006, 08:07 PM
Hey thanks for the reply, that worked fast. Now how about a quick, cheap fix for this intake gasket! Thanks again.
FixUrNissan
03-25-2006, 05:06 PM
thats not as easy. :)
shab_xp
02-24-2007, 11:27 AM
Hi FixUrNissan,
Thank you so much for your generous sharing of the trick. My airbag light had been bugging me for two years. I feel so relieved after I successfully turned it off by following your suggested procedure.
Altimania
03-23-2007, 06:38 PM
What does he mean when he says "door switch" what is the door switch?? Is he talking about the lock?? damn, people u gotta be a little bit more clear. I have the same problem but since I dont understand what "door switch" means Im still confused.
shab_xp
03-24-2007, 08:35 AM
Open your driver's side door. The door switch is a small black knob on the pillar between the front and the back door.
The point is that you should press the door switch before it starts to flash.
Altimania
03-25-2007, 08:11 PM
Got u, thanks alot, now it's crystal clear what he meant. Once again, thanks.
