Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-21-2006, 08:17 PM   #1
gpdxtrm
gpdxtrm Normal reputation
Question Dome Light Help Plz
My dome light hasnt worked since I bought my 93 camry. I first tried changing the bulb. No go. Then I checked the fuse, it was fine, but I changed it anyways. No go. Then I checked, and there was no power coming in the line. I need to know what my next step would be? I would like to avoid taking down the ceiling, but if that is necessary, I need some instruction on that. Any help appreciated, Thanks.
gpdxtrm is offline   Reply With Quote
Old 03-24-2006, 01:51 PM   #2
RIP
AF -Advisor
RIP's Avatar
RIP Normal reputation
Re: Dome Light Help Plz
Possibilities: broken wire at the back of the light assembly, integration relay, broken wire at the junction block. Download the manual listed at the beginning of the forum.
RIP is offline   Reply With Quote
Old 03-28-2006, 05:25 PM   #3
Daniel M. Dreifus
AF -Advisor
Daniel M. Dreifus Normal reputation
Usual setting for the dome light is to go on when a door opens.
Did you check the pin switches in the door jamb?
I've had to dissasemble and clean mine a couple of times, then the light works again. They look clean, but I used some WD-40 on the contacts and that seemed to solve it. They're held in with a 10 mm bolt.
Does the light come on when manually using the switch right next to it?
Daniel M. Dreifus is offline   Reply With Quote
Bookmarks
Google
Web AF
