94 Accord Ex front rotor replacement
D@N-Gerous
03-21-2006, 05:08 PM
I am replacing the front rotors on my accord. I have already took off brake caliper and shoes. I am facing 4 14mm bolts and a 36mm hub nut. Can anyone describe the process from there? I thought all i have left to do is remove those 4 bolts, remove a 36mm hub nut and the rotor should slide off easily. However, people at Autozone told me that there's more to it and i have to take the whole hub assembly off the axle. Any pictures and walk-thru's would be extremely helpful. Thank you in advance.
Chromedubs165db
04-21-2006, 02:30 PM
Sometimes there is a flat retaining screw on some honda rotors it would be flush with the rotor on the "hat" portion somewhere
BullShifter
04-23-2006, 09:28 AM
Your accord rotors are not as simple as one would think. They are pressed on to the hub. Your best off buying a repair manual or taking the hubs to someone who knows what they are doing.
