Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 03-21-2006, 03:15 PM   #1
ballarman2
ballarman2 Normal reputation
Send a message via AIM to ballarman2
Question Not your typical Oil Leak
I have a 1972 Super Beetle and im leaking oil from the main seal, at least I think its coming from there. The leaks are coming from under both sides of the engine case. How difficult is it to fix the main seal? Can a faulty oil cooler seal cause the muffler to spit oil? What should I do? I appreciate any advice.
ballarman2 is offline   Reply With Quote
Old 03-21-2006, 08:26 PM   #2
bluebug
bluebug's Avatar
bluebug Normal reputation
Re: Not your typical Oil Leak
If it is the main seal it will be coming out of the engine to tranny seam. If it is running down on both sides of the case aft of the mount flange it would be the oil cooler leaking. Oil cooler seal would not cause the muffler to spit, the cooler seals are external of the engine.
Clark
bluebug is offline   Reply With Quote
Old 05-13-2006, 09:49 PM   #3
VWfinatic27
VWfinatic27 Normal reputation
If there are leaks on the main and the thrust, the seals are probably worn which may be a sign that you need an engine rebuild
VWfinatic27 is offline   Reply With Quote
Old 06-05-2006, 11:30 AM   #4
dgee
dgee Normal reputation
it could be push rod tubes.
dgee is offline   Reply With Quote
Bookmarks
Google
Web AF
