Winter Ability??
BimmerCrazy
07-06-2002, 04:16 PM
Hi all,
I have done extensive research on buying a new 3-series (sedan or coupe) and the only thing that I haven't been able to find is the vehicles ability to drive in the snow. I know it has stability and traction control, but it's still rear-wheel drive. So my question to everyone reading is, in your experience, how well does this car perform in the snow and what precautions should be taken if driving in the snow (i.e., snow tires)? I hope you all have good news for this New Englander.
Thanks.
Hoosier
07-11-2002, 11:59 AM
I have one word.....awful. The DSC can only do so much, at some point physics takes over and Rear wheel drive+fat slick tires+high torque and horsepower=poor snow traction.
frankjp
07-11-2002, 01:32 PM
It shouldn't be that bad if you drive carefully and use common sense. I've driven a RWD car(Mustangs for the most part) for the last 12 years, every winter. I'm near Chicago so we get some good storms, not like the New England area but they can get nasty. It's something that takes getting use to, but you learn the car quickly and come around. The biggest worry I ever had was getting stuck in a parking lot or something to that effect. I did have trouble on the expressway about a year and a half ago, bad storm and getting up a hill was very tough. That was my fault though as I hadn't yet changed to other tires(December storm), still had 275/40-17's on. I changed to Dunlop 245 SP's and had no problems the rest of the winter...
I didn't use snow tires until the last couple years. They made a VERY BIG difference. I would definitely recommend them. The only thing is, they are not the best in dry conditions at higher speeds, tend to sway and such. But, if you are in a heavy snow area, it's the best thing you can do. You can look into the XI as well and get AWD...that will get you some more control too.
I know New England storms can be rough...and I'm sure you've had your fair share of experience. RWD is tricky at times, but taking it easy and some snow tires should be enough to handle it.
Best of luck!
bufguy
07-31-2002, 03:06 PM
Take it from someone from BUFFALO NY, Snow tires are a must. My 318ti with traction control and four snows is better than any FWD car I've ever owned. Call tire rack and order a set mounted on steel rims. Mounting and balancing are free, you'll save money on constantly remounting tires and most importantly you'll save your aluminium rims from the ravages of salt.
