Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-18-2006, 08:55 PM   #1
JOET/CAMRY
JOET/CAMRY Normal reputation
Question Door,trunk and ignition lock replacement for 1990 Camry.
Hello,
My girlfriend bought a 1990 camry 4 Cylinder (W/ 90,000 original miles) that has a problem with the lock for the drivers side door and the lock for the trunk. the 1 key that came with the car is the wrong one for these locks, however it works fine for the passengers door lock and the ignition. where can I buy replacment locks for this car so the same key will work with all locks and hopefully the ignition also. is the toyota dealer my only option. the drivers side door lock looks like someone tried to use a screwdriver on it so I don't think it can be saved if it's possible to take it to a locksmith and have the guts replaced in it and all the other locks/ignition, so I can use one key for everything.
as usual, any help/advice is appreciated.
Regards,
JOET/CAMRY
JOET/CAMRY is offline   Reply With Quote
Old 03-20-2006, 02:48 PM   #2
JOET/CAMRY
Unhappy Re: Door,trunk and ignition lock replacement for 1990 Camry.
Originally Posted by JOET/CAMRY
Hello,
Regards,
JOET/CAMRY
Anyone...
:attent ion
Old 03-20-2006, 09:36 PM   #3
Brian R.
Resident Chemist
Brian R.'s Avatar
Brian R. Normal reputation
Send a message via Yahoo to Brian R.
Give this guy a yell:
http://www.locksmithcharley.com/
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 03-21-2006, 09:33 AM   #4
idmetro
idmetro Normal reputation
Several years ago the drivers door lock in my 91 camry got progressively more difficult to open and finally you couldn't operate it with a key anymore. I pulled the cylinder and took it in to a local locksmith. He replaced some of the internal workings and suggested getting a new key made as well. His explanation was that vehicles were once made with locks and keys of approximately the same hardness so like my old chevy truck you could start the vehicle and then remove the key as it had worn so badly, now the key and the lock/ignition are made of metals of dissimilar hardness so one wears faster than the other (in this case the key wears faster) creating increasing amounts of slop in the mating surfaces eventually you are virtually trying to twist the thing in half but the key hasn't pushed the pins in the lock completely up and out of the way so you are actually torquing on the lock assembly/key leading to premature failure of one or both. I've had new keys made every couple of years since and haven't had any trouble. For the few dollars of the cost of a key just consider it a periodic maintenance item to keep you from getting locked out on the night of the 100 year storm....
idmetro is offline   Reply With Quote
Old 03-21-2006, 09:23 PM   #5
JOET/CAMRY
Talking Re: Door,trunk and ignition lock replacement for 1990 Camry.
[quote=Brian R.]Give this guy a yell:
http://www.locksmithcharley.com/[/quote]
Friend of yours? LOL
Regards,
JOET/CAMRY
Old 03-21-2006, 09:47 PM   #6
Brian R.
Resident Chemist
Brian R.'s Avatar
No, he has given alot of free advise here on this forum...
Old 03-22-2006, 07:50 AM   #7
JOET/CAMRY
Thumbs up Re: Door,trunk and ignition lock replacement for 1990 Camry.
Hello Brian R.
I thought you were joking when you said to contact WWW.LOCKSMITHCHARLEY.COM His website is a little odd. you know what the old saying is, you should never assume.... oh well. I'm sure he's a great locksmith. I live in Attleboro,MA. and he lives in Arizona. go figure.
maybe i'll take a drive down there one weekend in my spare time.
thanks for responding. take care.
JOET/CAMRY
Old 03-22-2006, 08:09 AM   #8
JOET/CAMRY
Hello Jdmetro,
My 1989 Camry had a key that was so worn I could start the car and remove the key from the ignition. I was having trouble with this key on the locks and ignition, but once I had a copy made everything was fine. thanks for responding. take care.
Regards,
JOET/CAMRY
Old 03-22-2006, 09:34 AM   #9
Brian R.
Resident Chemist
Brian R.'s Avatar
Hello Brian R.
JOET/CAMRY
I didn't mean that you should visit him. Send him an e-mail or PM (he's a member of AF) and ask him about your problem.
Old 03-24-2006, 07:11 AM   #10
JOET/CAMRY
Question Re: Door,trunk and ignition lock replacement for 1990 Camry.
Hello,
Regards,
JOET/CAMRY
Update...
I found a 1985 (first generation) camry in the auto salvage yard with the keys still in it. I would like to know if the locks and ignition/lock cylinder would fit and work with a 1990 (second generation) camry? I don't know if toyota changed the design of the locks and ignition/lock cylinder from one generation camry to another. if anyone knows the answer please respond.
any help/advice is appriciated. thank you.
Regards,
JOET/CAMRY
Bookmarks
Google
Web AF
