1999 Passat V6 - 114,000 mi.
Google
Web AF
ghite
03-18-2006, 09:51 PM
I am wondering if the fuel filter should be changed on my car and/or the distributor cap at 114,000 mi.? Occassionally the car won't start until 3-5 cranks and a couple pumps of the gas peddle. How do you check/change the distributor cap and can I easily change the fuel filter if necessary?:banghead:
veedubmechanic
03-21-2006, 12:10 PM
fuel filter every 30-40k miles.
there is no dist. cap
Have the t-belt/tensioners/ w-pump changed recently?
how bout the ect?
ghite
03-21-2006, 12:48 PM
The timing belt and water pump were changed once at 55,000 mi. and both again at approx. 104,000 mi. The second replacement was due to a bad/defective water pump. Unrelated to the current issue, I am hearing the same noise I heard just before the second water pump was replaced and it has been only 10,000 miles!
Anyway, this car doesn't have a distr. cap? No points to replace? I guess that is a good thing.
Is the fuel filter something I can replace on my own with very limited mechanical experience or should I take it in?
What is the 'ect'?
Thanks.
veedubmechanic
03-27-2006, 11:46 PM
fuel filter is fairly simple on fwd. 4-motion is not as easy.
ect= engine coolant temperature sensor. somewhat difficult on v6 to replace but with time and small hands you could do it. (on back on engine between engine and firewall)
ghite
03-28-2006, 01:21 AM
Is there a website or narrative directions you could give me to help me replace my fuel filter on my fwd Passat? I have never done this before. Thanks.
Google
Web AF
