99 Malibu Dies until hood is opened then shut!!snake-eyes01 03-17-2006, 08:38 PM Yep, crazy car! A few weeks ago when I put on the brakes the headlights would dim just a bit. Then just last week my coolant level light came on then the car just lost all power, no radio, nothing! Well, I checked all the wires & couldn't find anything. I shut the hood & went to try & start it & it started! Then it happened again a few days later, first the coolant level then it died! Again when I shut the hood it started! So from then on all I do is open & shut the hood & it runs! I have a new battery, alternator, fuel filter, spark plugs, wires, all the typical Malibu problems have been taken care of! Any ideas what this problem could be?? bluevp00 03-17-2006, 09:07 PM ill i can say is have it professonially looked at it could be something serious, check the sensors, or even the fuses or grounds for any problems Berty72 03-18-2006, 12:08 PM sounds like you have a ground issue! niccaleb112602 03-20-2006, 06:05 PM check your positive batt cable at the battery, i had mine do the same thing. they put two cables together and they corrode between the "plates" that bolt to your battery fastk 03-24-2006, 01:17 PM Yes, mine had same corrosion at the positive terminal. It was badly corroded and it was AC Delco battery!!! They say it is very common problem. Automotive Network, Inc., Copyright ©2012
