03-16-2006, 07:27 PM
Banned
Brake rotors and more
I am going to replace my brake rotors and pads on my 96 S-10 Blazer. Any suggestions on which to get?
Also...people are telling me to replace my spark plug wires and rotor and cap...what would that do for me? I'm curious.
03-16-2006, 07:46 PM
Re: Brake rotors and more
Improve your gas mileage
03-16-2006, 08:07 PM
First off welcome to the board.
http://www.automotiveforums.com/vbul...d.php?t=453370
Read that thread on your plugs, wires, cap and rotor.
http://www.automotiveforums.com/vbul...d.php?t=503231
Then that one if your going to do the plugs yourself.
With the brake rotors and pads, you get what you paid for.
I'd go with either the top of line semi metallic pads or the ceramic ones.
Rotors id get the ones that they offer their.Again it goes back to you get what you pay for.
Again welcom to the board and the experts will be along later.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3--> If GM engineered something to fail on this beast it has or will.  Repairs include w/in first 30 days of owning it: P1870, left front wheel bearing, gas cap, rad cap, idler tensioner, seat handles, and the list goes on.
http://www.automotiveforums.com/vbul...d.php?t=890449
Chime in ^ with any suggestions.
03-16-2006, 10:18 PM
Advisor/Moderator
What I recommend is the same thing I do on my own: The cheapest rotors that you can find. The best ceramic pads, (slotted and chamfered, with riveted on shims) that you can find. Bendix, Raybestos and Wagner all make excellent quality pads. Replace and lube all of the hardware. Make sure the pistons are not binding in the caliper bores. Make sure the rear brakes are working properly and adjusted correctly. I've been doing brakes this way for years with no squeaks, fade, or pull and typically get 50,000 miles on a brake job. Keep in mind that yes, I’m old, but the fact remains, it works.
03-16-2006, 10:28 PM
lol deja vu
03-17-2006, 02:46 AM
It will do nothing unless there's a problem with those parts.
03-17-2006, 09:44 AM
I agree with Old Master. You can get the rotors at any Pep Boys, Autozone or Advanced Auto and you will get pretty much the same rotor. They typically run about $30 each for the front, and a little more for the rear if you have rear disc brakes.
Definately get the better quality pads, go ceramic if you can afford them. I replaced my front pads with the sub $20 cheapies from Advanced about 8 months ago - had to replace them again because one of the pads seperated and broke apart, did some damage to the rotors. Luckily I was able to pull the reciepts and had Advance replace the rotor free of charge due to a failure of the pad. When I got the new pads I spent the extra $20 or so to upgrade to ceramics.
I really like the ceramics, they are what came OE on the blazers in 99. Less dust, and it seems like they are gripping a little better. From what I understand you can expect twice, or more, the life from the pads over what you would get with the regular semi metallics.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
