k20a or type r engine?
96teg
03-16-2006, 03:00 PM
i own a 1996 acura integra LS and i'm considering swapping out my motor for a 2002 k20a (type-s) motor, or a b18 that comes in the integra type-r...which would be the better buy?
CivicSpoon
03-16-2006, 03:26 PM
the k20 obviously, but it will be more expensive.
96teg
03-16-2006, 03:55 PM
yeah i know, but is the extra 1000-1500 bucks worth the extra torque? because the type-r doesnt lack much more than 20hp to the k20. im lookin for the best bang for my buck. at first glance, i knew i wanted the k20 but now that i think about it, im not sure if its worth the $5000.
CivicSpoon
03-16-2006, 04:35 PM
Personally I'd say no, and go with the Type R engine. It costs more to put the k-series in the car, because there are a lot more parts you have to buy to get it all to work. And with the $ you save, you can buy other parts to make the Type R faster than the K20. So based on cost and ease of the swap (and the fact that they're so close in hp and tq); I'd say the b18c is the best choice.
kicker1_solo
03-16-2006, 10:41 PM
agreed, keep it B series, that will be a direct bolt in for ya
rastilnmajere
03-16-2006, 11:32 PM
ok but i have heard that the k20a responds a heck of alot better to bolt on's
then say the type r. i see both sides of the arguement here personally i would go with k because i think 6 spd tranny would be sweetness.
CivicSpoon
03-17-2006, 12:26 AM
I've heard that as well. But for the price vs power, the B18c takes it. The K-series isn't a straight swap like the b18c is, so you have to think about the price of those parts on top of the more $ you're paying for the Type-S engine. So from purely an economic standpoint, the extra 8tq from the Type-S really isn't worth the cost. But that's just my opinion, I'm a K-series Hater (I think they're highly overrated). Now an H22a on the other hand :naughty:...sorry off topic.
gnushit
03-17-2006, 03:40 AM
i had a chance to buy a k20 (base engine) for $1,500 but i declined because after all the cost of converting the car, the cost would be over $5000 (not including labor). for show factor seeing a k20 in a teg is still sweet. for performance factor, stick with the b18c5 and spend the extra dough on mods (turbo?). oh yeah, rsx-s doesn't have lsd unlike the itr.
96teg
03-17-2006, 04:16 PM
I think i'll just go with the b18c5, but how much do you think a turbo will cost me? probably 2500? and which setup do you think would respond best and give the best power gain
dopenoze
03-17-2006, 05:01 PM
b18c5 turbo all the way.
96teg
03-17-2006, 06:20 PM
will an H22a fit in my 96 integra because its a hell of a lot cheaper and puts out the same amount of power
CivicSpoon
03-17-2006, 06:35 PM
Yes it will fit, but it's not cheaper. It will end up costing just as much (maybe slightly more) than the ITR swap. Like the K-series, it's not a direct bolt in swap. However, the parts to do the swap aren't as expensive as with the K-series.
96teg
03-17-2006, 06:57 PM
alright. i'll just go with the itr swap then. Thanks for all the help guys.
96teg
03-18-2006, 01:04 PM
which turbo setup do you think will work best with the itr motor?
CivicSpoon
03-18-2006, 01:19 PM
You won't need that much boost to make good power, because the ITR has high compression (11.1:1). So don't go too big on the turbo. Be prepared to spend some $ on the highest octane gas possible or even race gas, and get a good engine management system and pro tune. But personally I would either go as small as possible if you're absolutely set on turboing it, or don't do it at all until you've done a TON of research (which you'll need to do anyways). There's a hell of a lot more to it that just getting a turbo and slapping it on, or you'll just blow it up on the first run.
96teg
03-20-2006, 04:13 PM
besides a turbo, what is the next best way to achieve a good gain in horsepower (without using nos, or supercharger)
CivicSpoon
03-20-2006, 04:55 PM
Basic bolt-ons (intake, exhaust, header), cams (w/ upgraded valvetrain), and higher compression pistons. That's about it.
s13dr1fter
03-20-2006, 05:39 PM
ITB's oh yea!!
aikonix
03-26-2006, 01:24 AM
The price on a full K20A2 swap will be $10k, first for a teg, u wont ever be able to pass smog with it because it doesnt have the right emissions as a RSX has. The emissions for a rsx, they have somethings that would be a very hard for a teg, rsx has a emission device in the gas tank, and many other places. K20 swaps are much better then the average b18c5 swap. ive seen integra's run 12.6's with just k20a2.
but.. if u do the actual full swap and get it bar'd, u can sell ur teg for like $20k and make bank!
up to you. id recommend the b18c5 because it will be just a easy swap for a lot more power then stock teg motors
also it would be MUCH sickkker if u had the k20a2 in it because its a fuking k20! lol
