Re: 1999 F350 Brake Problems
Shooter,
There are two likely causes, the first is that the ABS system thought there was a need to intervene due to a sliding wheel. Given that sand, frost, snow, ice, etc can cause this especially on the REAR axle, that I what I would suspect.
However, as Dave pointed out, if the vehicle is equipped with the belt driven vacuum pump, OR hydraulically assisted brakes where there is a problem with the booster, pump, or steering gear that could cause the very same symptoms.
At any rate, given the fact that this HAS CAUSED an accident already, it is time to contact the folks at the "NTSB" to notify them of the problem. I would also call Ford's Consumer line, and with a copy of the dealer's invoice in hand notify Ford that the vehicle was brought in for this concern, and that the dealer found "no problem". Ford should also be told that the NTSB has been contacted.
Written LETTERS to the NTSB and Ford Motor Company WILL get a response.
