Re: oil on spark plugs
If you get oil on top of the plug it's not the valve cover gasket. It's the spark plug gasket. Replace them. Might as well do the valve cover gaskets too.
No, the oil is not going to pass the spark plug & drop into the cylinder.
You've still got bad valve stem seals.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
