Do you think 06 Nissan Titan rims will fit my 01 Tacoma?
Google
Web AF
boredracer
03-16-2006, 01:09 AM
Some guy is selling his brand new 2006 Nissan Titan rims which are 18 inch 6 lug rims. And I wanted to know if they will fit my 01 tacoma? I have a double cab 4x4 if that makes any difference.
Heres a pic of the titan rims if you want to see them...
http://doogs.typepad.com/photos/vehicles/nissan_titan.jpg
Flash75
03-17-2006, 05:53 AM
They may fit, I would ask to try one on the truck before making a decision. Even though the bolt pattern may be correct you have to consider the offset and the center hole diameter. The center hole on some vehicle wheels will not fit the hub on another vehicle. It can be modified by a machine shop, but unless you can buy the wheels dirt cheap it's not worth bothering with.
Clifton
Brian R.
03-23-2006, 10:42 PM
Welcome to the AF!
Offset is different. Nissan offset is +20 mm. Tacoma offset is +18 mm. Don't go for it unless you can fit them and see if you have clearance problems beforehand (although a slightly larger offset should give you more clearance on the brake caliper). Bolt pattern is same.
Google
Web AF
