turbo doesn't workqwerty2468 03-15-2006, 10:09 PM i took my car in to get fixed and they said the turbo doesn't work. i went home and re did some hoses and got it working. but it cuts out at 3000 rpms on 4th and 5th gear. so either i have the cut off with a turbo, or a gutless car with no turbo. How can i fix this???? Will12 03-16-2006, 08:18 AM Is the aftermarket air intake there? lude_si 03-16-2006, 10:45 AM Well make sure all you hoses are good and solid. It could be a sensor for it possibly but it sounds like your waste gate is stuck open or adjusted wrong also Im not real sure about this cars turbo set up but the blow off valve could be stuck. qwerty2468 03-16-2006, 07:51 PM the aftermarket intake is gone it is now stock. but i still have a gutless problem. where would i locate the blow off valve and the turbo waste gate? veedubmechanic 03-21-2006, 12:06 PM what do you mean the turbo is not working? there are no intake lines connected to the intake box.. just a secondary air plastic line thats on the front of the air box. the other hard line is for the evaporative emissions. utipassat02 07-31-2007, 12:06 AM i took my car in to get fixed and they said the turbo doesn't work. i went home and re did some hoses and got it working. but it cuts out at 3000 rpms on 4th and 5th gear. so either i have the cut off with a turbo, or a gutless car with no turbo. How can i fix this???? i own a 2002 1.8t and if you drive it too hard it will go into limp mode with only 4 pounds of boost. it will stay like that for a while or until i turn it on and off or just drive chill a little while. socal1.8 08-31-2007, 02:26 PM Well make sure all you hoses are good and solid. It could be a sensor for it possibly but it sounds like your waste gate is stuck open or adjusted wrong also Im not real sure about this cars turbo set up but the blow off valve could be stuck. thiss cars do not have a blow off valve. they have a bypass valve. see it has any cracks also check your intercooler for cracks vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
