safe boosthany 03-15-2006, 06:35 PM i just install my turbo system. i did not try any high boost tell now. i just try evet thing air circle and oil circle and and fuel system and i think every thing is ok. my question is what will be the safe boost to safe my internals stock engine componant? . and in future if decided to change the internal parts to work in high boost what shall i change? my engine id d15b vtec jdm and suppose to be 130 hp without turbo . i use 1: 12 fmu and walpro high pressure fuel pumo blitzcivic 03-16-2006, 03:30 AM 6-7 pounds of boost would be the max with your current set up. any more and you could damage a injector and even worst blow your motor. the fmu is ok for temporary use til you get ecu. check this site for upgrading your ecu. www.phearable.net (http://www.phearable.net) Automotive Network, Inc., Copyright ©2012
